I am gathering data for a baseline on my 2009 Cobalt SS/TC (LNF 2.0L) in preparation for a K&N short ram intake install. I've heard that it may skew the LTFT unless the filter is rotated so the metal rib is at the 11 o'clock position. However, I used my ELM327 datalogger (v1.5 BAFX) and the Torque Pro app to monitor LTFT, STFT, etc...
What I found was the LTFT remained at 0% regardless of load/RPM, while the STFT fluctuated between -5.47% and +11.72% essentially inline with the AFR on my RPD (the OEM display on the A-pillar that can show AFR based on the wideband O2) depending on what I was doing. While idling, the STFT hovers very closely around 0% (14.7:1).
Is this normal behavior?
If so, I at least have a baseline to see if the K&N SRI will throw off the LTFT and STFT. I am interested in the HPTuners VCM Suite so I can custom tune my LNF, but I've been using SCT's Pro Racer Package and Advantage software for about 10 years on my Fords and am unfamiliar with HPT.
