Results 1 to 7 of 7
Thread: My First 2011 Camaro Tune, Stalling issues
    Apr 2009
    PHARR RGV (TX)
    32
    Just tuned my first 2011 camaro everything is good but i dont get why it stalls once in a while, when trying to stall it and launch it, it just completely dies out, re-start the car and try to launch it again and it works with no problem. it just does it when ever, not specific pater or weather etc.
    Aug 2006
    5BA8
    3,253
    How about a data log of it doing it? And does it do it both with a box lunch and a bag lunch?
    EFI specialist
    email=[email protected]
    Oct 2008
    Mebane NC
    475
    Now that's funny
    Wrong PE table. Enable Traction Control System switches.
    Jun 2011
    Tucson, AZ
    295
    holy moly. as loppad said with that pe table. also your base idle timing at idle is only 13 degrees???
    2016 Hellcat Challenger, automatic, black on black with brass monkey wheels
    10.13@ 140 DA 5000 feet
    2.75 pulley, tune, drag radials. 10 percent lower od crank pulley, 1050 ix. off road mid pipe. tune
    Sep 2008
    1,668
    I agree that the PE is a mess...that combined with the completely stock MAF table and airflow model means you really haven't actually tuned the car at all...it really looks like all you did is go bananas with PE fueling, turn off engine related traction control (the BCM can still run the brakes though), crank up the rev limiter, and change some transmission stuff.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    Sep 2008
    1,668
    Quote Originally Posted by CactusG8 View Post
    His timing is stock. A lot of Gen 4 engines idle with the advance very low like this.
