Results 1 to 8 of 8
Thread: need stock 4.3L file
    Oct 2011
    24
    The file repository is blank on a stock file for a 4.3L Silverado 2001-2002. If anyone has one I would really appreciate it. Thanks
    Oct 2011
    24
    Anyone???
    Feb 2012
    14
    Try a S10 same year. Just remember (IDK if it matters) GM swapped from poppets to mini-injectors in 2002 IIRC. Also know if you have EGR and/or AIR....compare to the S10 year if it had it or not. I dont see why the S10 file would not work in terms of the settings. Same engine
    Oct 2011
    24
    Different part number on the pcm
    405
    2,315
    Quote Originally Posted by gmtechnician View Post
    Do you still need this?
    Feb 2009
    GA
    117
    Sorry to bring up an old thread but I need a stock tuner for a 2002 to 2005 S10 if anyone has one.
    405
    2,315
    Be more specific. An 02 is going to use a 0411 red/blue PCM and be a 512K file and a 03-05 is going to use a blue/green PCM and be a 1MB file.
    Feb 2009
    GA
    117
    Sorry I did not know that but I'm mainly looking for the injector setup so I can compare between my 2001 with the older style injectors and the newer style (2002 to 2005). I upgraded mine and want to compare the two setups. I would think the injector setup should depend on the injector and not the system it is connected to but I'm no expert. I'll take what I can get because it seems no one has a stock tune.
