Results 1 to 3 of 3
Thread: 4.3L pcm question
    Oct 2011
    24
    4.3L pcm question
    Im putting a 4.3L engine out of a 02 Silverado into an 80 model jeep. I had a custom harness made from Hot Wire they gave me a part number for the pcm that I needed. When I went to the salvage yard the only pcm they had with that part number was for an 02 Escalade 6.0L. I called O'Reilly and they said that the v6 and v8 trucks pcm shared the same part number. So can I just copy a v6 truck tune into the v8 pcm and it work? thanks
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by gmtechnician View Post
    As long as the service number is the same. Both of those should be the 0411 PCM's. If so, then a full write of the V6 OS will work. If your a GM tech, cant you just load a new GM cal at work?
    Jaime
    Oct 2011
    24
    Ok i will try it. Yeah i quit the dealership after ten years in search of paid retirement.
