I recently bought a new computer that has windows 8. I loaded the latest version of editor and scanner and loaded the windows 8 drivers. Device manager recognizes the mv when it is plugged in, when I use the editor it will go through a read as normal but once you try to save the file it says to email support because there was an issue. When I try to use the scanner it won't even connect. It will connect to the MPVI in both programs and tell you license info. Any help would be greatly appreciated. btw, I had this installed on windows 7 on the last computers and has been working fine until the laptop screen took a poop
