Am I missing the KR?
'04 hemi ram, using the HPT scanner, its working well, except... There isn't KR or Inj pw, Am I missing it, or is it not available yet?
Are you on the latest software version? If so, find the Scanner vehicle configuration file that matches your truck VCM and delete it. Then, reconnect the scanner to the truck. It should re-poll for supported PIDs. If it doesn't poll for at least 150 or more PID's then you'll need to send an infolog to support and see if they have defined them for that O.S.
http://www.hptuners.com/forum/showth...l=1#post319549
Here is a link to my description of where the file is.
So, I tried that (deleting the .os file), it re-polled and KR is still not there. Its the latest version. Any thoughts?
May not be available for your OS yet
My 05 is hit and miss with that magnum config, but it does work. Sometimes I have to start the program a couple times and switch configs back and forth, but it does eventually work
