Hi Tom!!! How's the Bee doing? I'm at 650whp/609wtq now with my LSA Sky on pump gas and stock injectors. The gas tank is WAAAAAYYY too small to run any Ethanol mix! Nice to see you're still keeping an eye on these young'ns here.
Matt, save yourself a bunch of headache and just use E47. When the tank is empty just put 6 gallons of premium and 6 gallons of E85 in it. Full E85 in an LNF actually makes LESS power than E47. You get into injection window misfires and fuel pressure issues. On E47 you can run up to 26 degrees ign timing, there's really no more power going higher anyway. Many studies have shown the knock reduction from Ethanol drops off after as low as 30-40% anyway.
On the 5th injector issue... There's only one guy that's come up with a system that works. (hmmmm, who could that be?) ZZP's setup is garbage. Stupidest idea I've ever seen to inject ANYTHING into a tiny little bowl that then has to run through a passage to get into the intake manifold. Whatever atomizing the injector did to the fuel is lost as the fuel gathers in that bowl and turns back into liquid fuel. They don't care though, and their customer base is too stupid to know any better either. Again, if you're gonna try a 5th injector, save yourself a bunch of trouble and just copy my design. A bunch of guys already have and I've yet to see a problem with any of them out there. It's a good design, very similar to the old Throttle Body Injection where one or two injectors sprayed into the manifold above the throttle plate. Sure it wasn't as good as Port Injection, but it worked. What my design does is sprays the fuel directly over the throttle plate. There's no way you could possibly get any pooling or uneven fueling to any of the cylinders. As far as what to run through it, I took my feed right off the low side fuel pressure test port. You never have to worry about filling a tank, and the low side stock pump is plenty good for ~500whp if you bump the pressure up. I'm not a fan of water/meth injection, but yeah you could run that through a 5th injector. I personally would rather run E47 out of the regular gas tank, or E85 if you want to setup a separate tank and pump.
FWIW, ~500whp is a reasonable goal on an LNF Kappa. Anything past that and it gets a LOT more difficult. There are dozens of Kappas running around out there at 450-500whp pretty reliably. As long as your goals are below that, it's all been done and documented by others so just do the same and you'll be fine. If you want more power than that, get ready to spend some time and money!
Here's some pics of what my 5th injector setup looked like. It's still alive and working fine on a gal's EFR Sky in Texas.
http://i841.photobucket.com/albums/z...s/IMG_2404.jpg
