I cant figure out why when I log engine delivered torque it maxes at 640. Is this something I can change on the E38 ?
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
I've only seen 635 to date on mine so I don't know if there is a limitation or not. Guess I'll find out when I pulley down.
Ran into the same issue now that I'm at 9 psi. Anyone know?
That is the max limit.
You can rescale the MAF/IFR to lower the torque signal so that you can still see a full curve. Lowering the torque signal will affect A6 tune parameters though.
2004 GTO A4
UNDER CONSTRUCTION....
Previous E.T. 10.66 @ 130 mph
http://www.mongillomotors.com/1066vid.html
2008 G8
LS3 76mm Turbo. 582rwhp
2003 S600 Mercedes
V12 Twin Turbo 21psi 600 rwhp
2007 Factor Five GTM
Twin Turbo forged LS6 600rwhp
2015 Polaris Slingshot
Tune & DR
www.ProEdgeTuning.com
Tuning with HPTuners & Mustang MD-1100 Chassis Dyno
Wallingford, CT.
[email protected]
