When tuning Wot can u remove one of the oxygen sensors and use that bung for your wideband? I know the o2 do nothing in pe mode so it shouldn't matter right??
Yes you can just set it up for open loop and disable the codes that pertain to that sensor. You need to tune the VE/MAF tables before moving on to PE.
1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
- 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
