Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: Spark Control over 1.36G/Cyl
  1. #41
    Too bad older PCMs can't get the editable axis labels for spark...
    But there is a Scalar that multiplies the G/Cyl output.. that should work w/o needing to scale everything just because you are hitting the top of the table.
  2. #42
    Jun 2008
    Charleston, SC
    969
    where?
  3. #43
    Jun 2011
    Montreal, Canada
    758
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  4. #44
    Tuner in Training neoh2ning's Avatar
    Nov 2007
    23
    wow thanks a lot great idea to use the spark AFR to reduce timing
  5. #45
    Jun 2008
    Charleston, SC
    969
    Just noticed on my logs that the PE/COT table interpolates between values, So now moved my BE/PE values around to take advantage 1.2, 1.225, 1.25, 1.275, 1.3 .... 0 in the 1.2 row, -2 in the 1.25 and -6 in the 1.3
    1.20 = 0 timing retard = 0-2psi
    1.225 = 1 degree retard = 2-4psi
    1.25 = 2 degree retard = 4-10psi
    1.275 = 4 degree retard = 10-16psi
    1.3 = 6 degree retard = 16-up
    1.
    -Carl
  6. #46
    Quote Originally Posted by realcanuk View Post
    Sorry to see that damage Bill. Hope you get it back together soon.
    On the topic of this thread.. a question from a beginning tuner.I am faced with this 1.36 cyl air limit on my boosted LS402.
    I have it set at 19 degrees at 1.36 and it carries the 19 degrees from there on up, so I assume it just uses the last cell. Is there a problem with just leaving it like this. It carries the 19 degrees to my max boost which is abouth 12.5 lbs, and that is ok with me. i guess if I went to any more boost, I would definitly have to work around it to drop timing.
    I guess my real question is, other than controlling timing, does that 1.36 limit impose any other issues.
    Bump for an answer..........
