Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: Spark Control over 1.36G/Cyl
    Jun 2008
    Charleston, SC
    969
    What are you guys doing?
    This is my band-aid solution:
    Step 1)Right now I hit the bottom line 1.36 g/cylat 8psi boost. So i set my main table to that 18 degrees.
    Step 2)I set BOOSTPE to 1.2(12.2afr) up to 8psi then 1.25(11.7) up to 12psi then 1.30(11.3afr) up to 16psi, then 1.35(10.9) up to 21psi
    Step 3) Using the Spark AFR Correction table zero it out, then starting at the 1.25 line add -2 degree, 1.3 add -4 degrees, and -6 degrees for 1.35
    verify.
    8psi commands 18*
    12psi commands 16*
    16psi commands 14*
    20psi commands 12*
    If only the Spark AFR correction table had more resolution or had an adjustable axis for PE labels. you could get away from dropping the afr so much.
    This with the IAT table makes it douable. and if you're a big dog like 5_litr, you could always start with 16psi, the crank it up to 21+ oke:
    lets hear what you have tried. and i know, just scale the tune 50%, but i always end up with idle return issues doing that. cutting ifr and doubling stioch works flawlessly except the 1.36g/cyl spark table.
    -Carl
    PS. Airflow>General>Spark Airflow
    If i half the value will it double my resolution on all my spark tables?
    i dunno what OS you have but the newer ones have configurable airmass axis on the spark table.
    I count sheep in hex...
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I do exactly what you do, Carl.
    FYI, don't scale idle parameters and you won't have a problem.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,025
    Quote Originally Posted by carlrx7 View Post
    Step 1)Right now I hit the bottom line 1.36 g/cylat 8psi boost...
    ...and i know, just scale the tune 50%, but i always end up with idle return issues doing that. cutting ifr and doubling stioch works flawlessly except the 1.36g/cyl spark table.
    You have answered your own question. Scaling is the exact thing that fixes this correctly. You just need to be faithful about scaling EVERYTHING with g, g/s, g/cyl, torque, displacement, and throttle area. There is no halfway when it comes to scaling some things and not others if you want it to work correctly. Also, nobody says you need to scale 50%. Pick a different factor that gets you just inside of whatever limitation you're hitting first.
    Jun 2008
    Charleston, SC
    969
    With my injectors. 50% is the minimum I have to scale in order to make them fit. Can anyone key in on the spark airflow multiplier table if .5 works?
    06 Corvette E38 FTL
    Dec 2008
    on the Dyno
    1,825
    I know its been stated that you cannot simply use the multiplier vs volts or IAT to get IFR back up to actual flow rate because of the 63.xlb/hr limit. But I like tying stuff anyway to see what it'll actually do. My reasoning for trying this is from back in the Gen3 LS1's. They have a 512g/sec limit on airflow, in SD that limit is not there but datalogging a healthy car in SD with dynamic airflow still pegged the 512 g/sec limit even though it was actually getting more and targets fueling was kept in sync. So I wanted to see if the limit for injector flow actually existed or was just a scanner and table limitation. Turns out it is true... Using some 80lb Siemens injectors halved in the IFR table and a multiplier of 2.0 in the voltage multiplier table the MAF table was off. A 550-600rwhp Cam'd LS7 was running commanded fueling with only ~300-325g/sec of airflow. That was my sanity check on the flow and told me that injector scaling and tune scaling is a necessary evil on these cars.
    Anyway just wanted to show my results from a little testing I had done.
    Located in Central Kentucky
    ShorTuning
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by LSxpwrdZ View Post
    I'm not refering to using any of those IFR multipliers
    Dec 2008
    on the Dyno
    1,825
    I know.
    I use the AFR spark for different boost levels based on the EQ. Just like you stated. However most of the setups that I have tuned have scaled tunes to get the injector data correct around that 63.x limit and thus turns that 1.36g/cyl into 2.72g/cyl which is enough for ALOT of HP and keeps me on the table for timing adjustments.
    ShorTuning
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    Quote Originally Posted by Chris@HPTuners View Post
    ^ I used this method on our Silverado... As fas as i can tell, it works like a charm..
    Mar 2008
    St. Louis, MO
    4,860
    Too bad older PCMs can't get the editable axis labels for spark...
    Jun 2008
    Charleston, SC
    969
    Yea, I put in a request and was given the same response.
    http://www.hptuners.com/forum/showthread.php?t=42435
    Should have sold my car way back and picked up a 09, even 08's have adjustable spark tables. Not sure why it would be hard to add it to the custom OS for those two years (06-07).. or at least mine!!! 1250202
    Jun 2007
    Finland, Europe
    549
    I've noticed this as well, but how come...:
    Quote Originally Posted by eficalibrator View Post
    For a guy who's tuning just a handful of engines per year, this is really challenging to follow.
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by Pekka_Perkeles View Post
    The idle airflow parameters have no bearing on actual fuel delivery. These airflow values are only a link to a throttle position. Scaling idle airflow parameters usually causes more problems than neccessary. I've scaled a lot of vehicles, and have never scaled the idle airflow, and it's always been perfect.
    Jun 2007
    Finland, Europe
    549
    Thank you.
    Nov 2005
    Houston, TX
    3,968
    LOL, well that didn't work out so good...http://www.youtube.com/watch?v=WjqqkgMttpw
    I guess I'm lucky RE: the spark table. With the 50% scale I have for my 1k injectors my spark table maxes out where the 2.5 bar MAP does. On gates (~10#) it logs in the .92 row. 21# is in the 1.36 row. Maybe E40 FTW on this for once.
    Bill Winters
    Out of the LSx tuning game
    47
    Magic smoke lol
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by 5_Liter_Eater View Post
    Turbos or engine?
    Nov 2005
    Houston, TX
    3,968
    Engine. Grabbed 4th and clicked it up to 21# and it started missing and then the car was engulfed in smoke. Oil pressure was fine and I was able to limp it a few miles but once I shut it down it didn't want to start again. Cranks very slowly. Tons of oil in the intake, pooled up behind each intake valve. Ahead of the throttle body is dry. I expect to find a hole burned through one or more pistons.
    Bill Winters
    Jun 2008
    Charleston, SC
    969
    Ouch! sorry to hear! but when life hands you lemons you upgrade to a C7!!
    Nov 2005
    Houston, TX
    3,968
    LOL. If I did anything it would probably be a GTR. But I'm sure I'll end up going .005" over and throwing new pistons in, lower CR this time.
    Bill Winters
