just calibrate it for the fuel it wants to see and leave it alone until you get your turbo finished.
Ok here is log finally missing under boost afr at 11.7 wideband is not set up gonna have to re do again
Not wanting to be a dick here but you have Fuel Trims OFF and NO WIDEBAND,
How are we or You supposed to tune fuel if there is no Data logged for it?
Also you are not using that Config I posted or deleted vital info from it.
Lastly and most importantly you are still way lean and looking at O2s in the 100% TPS range your engine will not last much longer.
Yes you are missfiring under boost, its a LEAN MISFIRE
