Seriously! Now that I grabbed your attention, this is on a 2010 Silverado with a forged LS7 427 transplant and a TVS2300 and literally modified every single thing. I was having a transmission problem, and was diagnosing why the truck felt different after just a 1 3/4" with 2" merge collector to a 1 7/8" to 3" merge collector swap. Figured out I was hitting a higher MAF range at WOT, a range that I had not previously touched and thus was untuned for my combo.
Broke a rocker arms, valve spring, bent a pushrod. Replaced the entire valvetrain after a downtime of three weeks and im back to tuning and this is the problem I face:
Im using an NGK AFX wideband, and quite recent beta version of the software. Wideband is placed after the x-pipe because id rather have an "averaged" reading from both cylinder banks, taking into consideration that readings are slightly richer at the collector, like 0.2:1 richer than placing it where I have, so as long as I account for this (which I am) im good.
I disable closed loop operation and long term fuel trims and zero out the trims, I dont disable DFCO because I have deceleration data filtered out to begin with by means of a filter that reads about 2% higher TPS than idle. I cruise around and collect as many data points as possible, the motor tends to get into boost really quick skipping over alot of cells so I drive in a way that allows me to collect as many data points as possible in all cells. Two to three WOT pulls and I work the MAF curve by multiplying HALF the AFR error into a new MAF curve. Few repititions this way and I get a MAF error that is from 0-2% off which is acceptable by my standards.
Now the problem im facing is the following:
- even with the average AFR error as close as possible to zero, there is still a discripancy between commanded AFR and actual AFR.
- AFR varies between a second gear pull and a third gear pull, getting richer the higher the gear
- AFR would jump from 10.9 at night to 11.8 in the morning
- at a given MAF frequency say 5000HZ. actual afr would be lean at cruise and pig rich while coasting down after a wot pull, both while commanded afr is stoich at 14.68
- Truck does not get into DFCO, and when I forced it into getting into DFCO it acted very funny, so Im under the impression that you do not want an automatic transmission car to get into DFCO unless you have the ability to maintain a locked torque converter at coastdown.
1) Im trying to find out WHY am I having those problems? Are there any fueling enrichment tables that HPTuners is not displaying? something like an IAT enrichment table, or ECT enrichment, gear enrichment etc...?
2) why do we filter out deceleration data when tuning using a wideband in open loop? do we filter out deceleration data when tuning idle/part throttle using the narrowbands?
3) Does this sound like a bad maf placement by any chance? Im attaching a picture of how the MAF sensor looks like on the truck.
Im about to smash the laptop trying to figure this out.
*included image of the MAF location, latest hptuners file and log, look at frame 28185 for the post WOT richness, and a config*
