I am trying to log AFR on my Z06 but find myself on a snag.
I followed this guide perfectly to my knowledge.
http://forums.corvetteforum.com/c5-s...hp-tuners.html
Used pin 55 and ran the output 0-5V from my PLX box to that pin.
The gauge coming from the box is working great, but it's not logging when I log.
Any help would be greatly appreciated!
I have attached for ease my config file, a log and my tune.
Electrical things are not my strong suite.
Cheers,
-Hippo
EDIT:
I think I may not have properly hooked up the PLX box to the EGR. Does it need some type of ground coming from another slot on the analog?
I'm looking at the install manual for it here.
http://www.plxdevices.com/support/ma...UsersGuide.pdf
And for the place where you insert 4 wires under "Analog" on the back of the box, the instructions are quite vague if someone could tell me EXACTLY what I need to put into all 4 slots. I currently have the 0-5V output to the ECU on the bottom right and a wire from the gauge going into the top left.
Thanks!
