Results 1 to 9 of 9
Thread: back to back pulls way different afr
    Dec 2008
    39
    i did two back to back maf calibrations while resetting the scanner between the two pulls. the first one is lean the second one lean?????? could i have the injector info wrong
    id850
    return style fuel system
    2012 camaro
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Injector data isn't quite right, but it should suffice. I'd make corrections to it just in case, since these are 98.34 lb/hr, not 99.40
    618/618 motor
    906/862 spray
    Dec 2008
    39
    ok i switched that. but that wouldn't explain the difference between the two pulls
    Aug 2010
    Roswell, N.M.
    1,956
    Is this car on a dyno or what the hell is going on? 38 kPa manifold pressure at the end of the pull? Where's your wideband info? Is this car boosted? Was that a WOT pull?
    618/618 motor
    906/862 spray
    Dec 2008
    39
    Quote Originally Posted by IDRIVEAG8GT View Post
    ya its on the dyno, shit ill forgot to post the config. not a wot just calibrating the maf 0-6200 hz
    yes it has a maggie 11PSI
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Ernie@PSR View Post
    Well it's in PE when it shouldn't be. It should always be at ~stoich. Set your MAP enble to 89 kPA, then set your TPS enable to 5 and zero out the delay and all that other crap incluiding the rpm delay table. Set your PE to 1.280 across the board, then relog. Your O2's should be oscillating and also, on a side note, load the dyno and spot tune different parts of the MAF X-fer. Free revving the car is hard on parts, and no one really drives like the way you are tuning it. I would really only think you'd see a max of 3500 rpm or so to nail down that portion of the tables.
    618/618 motor
    906/862 spray
    Dec 2008
    39
    i have a 13% load on the dyno. how is it PE, the commanded eq is still .999 through the pull. i have it open loop to tune. if you look at histogram setting number 8 that is lmada error per maf hz
    Aug 2010
    Roswell, N.M.
    1,956
    I'm looking at your B2 STFT's which shows to be rich as a motherfucker. 930mv and staying is figuratively 11.5 AFR. That's just an educated guess, but seriously it looks way too rich.
    618/618 motor
    906/862 spray
    Advanced Tuner Jabbott's Avatar
    Oct 2006
    Richmond
    223
    You can't just free rev it, the car has to have load. Start doing your pull, if it gets to far off either way you can just add or subtract to the entire maf x function.
