Results 1 to 9 of 9
Thread: 2012 camaro tries to on coast
    Dec 2008
    39
    2012 camaro tries to die on coast
    2012 ss
    maggie making 10.6 psi (3.2 upper 10%od lower)
    kooks 1 7/8
    catted x
    built bottom end
    stock throttle body
    cam 566/576 222/234 113lsa
    ID850
    twin 405LPH (Return style) 60PSI static fuel pressure
    when coming to a stop this car always wants to die and barley catches itself. you can see after WOT the fluctuation (note this is on on the Dyno with the load on 12%)
    Nov 2009
    All Around
    3,149
    ur file is locked
    Jun 2008
    Charleston, SC
    969
    tuner locked
    Dec 2008
    39
    here we go. i have also read something about scaling a tune with ID850's. Why is this needed and if i need to do so how do i go about do it? i half to do it to a lot of the Fords i tune due to them seing over 200% load.
    Aug 2006
    5BA8
    3,051
    Looks like just not enough idle aiflow.
    EFI specialist
    email=[email protected]
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,856
    No scaling required on the fifth gen Camaro PCMs for ID850s.
    Definitely needs more idle air.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Nov 2009
    All Around
    3,149
    idle airflow needs to be adjusted, and also the PE throttle Pedal in lower rpms has around 35%tps
    maybe there is a conflict, between your enabling PE 90kpa and throttle table.
    Dec 2008
    39
    Thanks guys, ill try adding 15% and see where that gets me
    Dec 2008
    39
    i got the stalling to go away, now the idle afr is going everywhere. at start up it goes rich then leans out to 15.6ish then after the pull it goes to 14.4 then starts going lean.
    also on a side note is it normal on the 5th gens after a flash to take for ever to come up to 1.00 commanded EQ. it always start at .88 then after about a Minuit if finally hits 1.00
