Results 1 to 4 of 4
Thread: Simple question regarding enabling tm...
    Jan 2012
    33
    I am currently running no tm and am thinking of running some. I am wondering where I enable it and where to control how much. I am looking for mellow around town and very little tm up top. Thanks for any input.
    2009 Pontiac G8. Camaro 3.45's, 222/230 114+2 .59x/.60x, VCM intake, ported intake/heads/tb, 1 3/4 Kooks lt's, Solo hf cats and cat back, udp. 12.2 @ 117 2.05 60 ft.
    Apr 2005
    Sugar Land, TX
    1,198
    This would reduce TM by 1/2 on the 1-2 shift. If you want to reduce by 3/4 then type in .25, etc. I have to have some TM on my 1-2 or I get tire spin so I like to use .50 on the 1-2 and .25 for 2-3 and 3-4. By sure TM is enabled.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by 8850 View Post
    Thought A6 time was part of the adder/modifier tab right below the table you listed.
    618/618 motor
    906/862 spray
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by IDRIVEAG8GT View Post
    You may be right but I know this table increases my advance at shift from some where well into negative values to all positive at shift with .500. I was very happy with the way shift felt at .5 that I did not try a lower number.
