Results 1 to 5 of 5
Thread: New port/polish Throttle Body idle issues.
    Jul 2012
    near Asheville, NC
    49
    I have installed a port/polished TB on my 07' Avalanche 5.3L. It is the same size "87mm" as the stock model. Upon starting vehicle, the engline will initially idle a bit high by about 400-500 rpm for a few secs, then settle back to normal range. While in park, if i moderately press gas to about 3000 rpm, it will very slowly return to normal idle instead of falling at a normal faster rate. Shortly after starting, as soon as I put it in gear or reverse then it will take off on its own with "no gas applied at all", not insanely fast but definitely a problem. Finally, when cruising around and letting off throttle completely and using brake, I can still feel truck trying to slightly push through the braking a little. Obviously my brakes are gonna wear very soon until I fix this. This is a replacement TB as the first one did the same thing and I thought that maybe it was a defective TB, but it behaves the same. My 09 Corvette has a TB also from same guy, but it performs flawlessly. Any ideas on how to tune this down? My tune is attached.
    Jul 2012
    near Asheville, NC
    49
    My current tune
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    It should settle in after driving awhile. If not, you may have to adjust your min airflow table.
    Jul 2012
    near Asheville, NC
    49
    I multiplied minimum idle airflow table by 0.80. It is acting much closer to stock now. I had to raise 1st gear shift mph points by a couple mph. It was shifting into 2nd very early with the stronger throttle response, which is dramatic by the way.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Adjust the airflow step up, down some.
    618/618 motor
    906/862 spray
