Results 1 to 6 of 6
Thread: 02 Trans Am dies, low power??
    Dec 2012
    Wichita, KS
    10
    trying to help a friend out with his car. Car seems to have issues idleing, really just driving in general, and seems to be underpowered for what the build is. Also has a dyno sheet with 499 hp on it ( i know its not anywhere near that, nor anything to go by) but here is the run down. Im very new to tuning, but it seems like 28 degrees would be alot of timing.
    Also i know i dont have a lot of posts, but i have been reading alot, and just havent been posting.
    2002 trans am
    GM LS2 block honed .005
    Stock crank
    Eagle forged H Beam rods ARP bolts
    Manley flat tops with 2 cc valve relief
    Stock L92 head gaskets
    L92 heads unported milled .030
    PRC .660 lift springs (not the .650)
    Comp cams hardened push rods
    LG Motorsports G6X3 cam
    Unported L76 intake
    FAST 92 mm tb
    Smooth bellow
    FTP 98mm lid
    Brand new k&n
    60# injectors
    6 speed
    3:90 gears
    longtubes
    Also added a copy of the tune. See what you guys think.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    This is Gen III stuff. Just a heads up. But I'll take a look at the file tomorrow for you. I bet it's going to be pretty hairy.
    (For 91 octane or better with nearly stock compression and a decent cam, 28 degrees is a perfect amount. A stock cam would warrant less ignition timing to be used as we're talking about a fairly good sized cam.)
    618/618 motor
    906/862 spray
    Dec 2012
    Wichita, KS
    10
    SOB... lol I kept going over LS2/L92 stuff, not even thinking im still using LS1 computer. Yea if you could glance at it that would be awesome!
    Aug 2009
    Calibrating
    3,373
    Doesn't matter what computer you have, its what the engine wants.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Ben Charles View Post
    Air/fuel/spark? And oil.
    618/618 motor
    906/862 spray
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Crack the throttle blade open more.
    http://www.dsxtuning.com
    Just say no to bull s***.
