Results 1 to 3 of 3
Thread: Idle Issues
    Jul 2011
    Lubbock TX
    55
    Idle Issues
    Ok so i have a 2008 1500 truck that had a 4.8 L, it now has a 6.0L out of a 2011 truck, we put a small comp cam in it for torque, you cant even hear it at idle. but for some damn reason this truck hunts for its idle. i have tuned the VEs and the maf, the LTFT look good, i have tried changing the spark idle correction tables and that does not help, i have also tried changing idle speed and the base airflow final minimum and neither one helps.
    the injectors throttle body and intake are all from the 6.0 L which i believe are 36lb injectors which is what i tuned for.
    If some one could please look at this tune and the logs that would be great!
    Attachment 38083
    Attachment 38084
    Attachment 38085
    Jul 2011
    Lubbock TX
    55
    It seems like the more i drive it the better it gets, maybe the throttle body just has to relearn.
    Jun 2009
    usa
    27
    if you have changed the cam and [or cam position sensor]you may have to do a relearn.
    this takes a tech 2 tool to do this.
    when i changed my 5.3 to 6.0 [added a cam]i had to do a crank and cam relearn.
    takes 3 minutes with a tech 2 tool.
