RPM/Engine will Not Respond to Pedal, CAM Tune E38 HELP!!!!!!!!
Hi! truck idles fine and drives well but when you Press the Gas 100% WOT it Does Not Respond rpms very Slowly Merge to 2800-3K rpm and it just doesnt accelerate on Both P/N/Gear rpms will not go up in accordance to throttle position, im thinking its a ETC table or something but just dont know id like if you guys could Help or give me tips on what table to mess with, I will upload Tune & Log 2morrow anything i should Log in Specific?
Vehicle Info: 2010 Silvy, Originally a 5.3 Swapped for a LY6 6.0L, 243Heads, DOD Delete, 232/236 .595"/.598" 112+2 LSA , 3600 Single disc Stall, 4.11s, LTs, CAI
Please Help!
Thanks!
HPT file tune attached
your trans input torque max looks very low. try increasing this value in torque management and try again. also etc traction control is still enabled - might try disabling this also
