Results 1 to 16 of 16
Thread: torque #'s are very odd dyno and tune attached
    any thoughts on was this looks this way
    not spinning and clutch was holding
    walbro 465lph pump
    E85
    2000cc injectors (full return style system)
    408ci(stroked 6.0)
    ls3 style heads 11.8 comp
    Attachment 38049
    Attachment 38048
    2002 Z06-408LQ4 583RWHP 496RWTQ on E85 / 919RWHP 895RWTQ @300 shot
    Apr 2009
    613
    Do you have a log?
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Roads still a little wet I'll post a log today any thing specific you want to see
    Apr 2009
    613
    I meant from the dyno pull. A wot pull showing the normal stuff make sure to log airflow,timing,knock
    Aug 2006
    5BA8
    3,203
    Quote Originally Posted by 260B4U View Post
    A log from that dyno pull.
    EFI specialist
    email=[email protected]
    i dont have logs from that run tuners laptop was used but here some from today
    Attachment 38059
    Attachment 38060
    Attachment 38061
    Attachment 38062
    Attachment 38063
    and one more
    Attachment 38064
    Any one ?
    i guess nobody has a clue
    the motor is sound comp and leak down is good. "fresh motor"
    its got to be in the tune ?
    Aug 2006
    5BA8
    3,203
    Kinda hard to make an assessment without a data log of the run. Could be the tune, could be totally unrelated to the tune.
    The couple data logs I looked at, did not have a steady 3rd or 4th ger pull that even closely resembled a dyno run. Even if they did, there's no telling if the load was the same as the dyno.
    EFI specialist
    Oct 2008
    Mebane NC
    475
    just curious, since they have and stored all the data can they add a MPH graph?
    Aug 2012
    Huntsville, AL
    122
    Four major dips; just looks like where you were shifting to me.
    Jason
    01 Camaro Z28 LS3 525hp Built 4l60e
    74 Camaro Z28 LT 355 fully forged roller with t56 4.56 gears
    Quote Originally Posted by kyphur View Post
    This was on a dynapak dyno 4th gear pull
    I think it might be a fueling issue it seem to corelate to a fuel pressure bouncing e en though the wide band at tail pipe doesn't register a change in AFR
    Tuner in Training TeamLS's Avatar
    Feb 2013
    21
    is it just me or does anyone else think in log 8 his AFRs are everywere but were they should be?
    HJ ute-LS1-Cam-Nitrous-9"
    GQ Patrol-LS1-8" Lift-Fun
    VK Calais-LS1-Cam- in the build for the missus to skid
    Quote Originally Posted by TeamLS View Post
    where do we think they should be? i was aiming for .78-.81
