Results 1 to 6 of 6
Thread: no tcc lock up
    no tcc lock up
    Can some off you take a look at this file and see if you can see something im misssing. This is a ls-1 swap, I can lock the tcc up just fine useing the ecm controls and it works great it has a 9.5 inch FTI converter. But the ecm will not lock the converter on its own. I have a traced it down has a wire going to pin 33 on the blue ecm connector. I can watch the scanner and when I push the brake the scanner shows it working on and off. I can not find any other wires needed to the ecm but maybe I am missing somthing. And the speedo works fine and all the shifts are fine. If any one can see somthing in this file that is wrong please let me know thanks
    Jan 2011
    30
    Could you post a log file? That will give a better picture.
    Aug 2009
    Calibrating
    3,375
    With a converter I would adjust the TCC minimum, most aftermarket converters don't have as good as a lock up clutch.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Quote Originally Posted by Ben Charles View Post
    It has a 3 disc locking clutch its rated at 1000 hp to stay locked, I
    Know during all of our dyno runs about 35 total runs it never sliped
    But we always locked it useing the ecm controls on the lap top,
    do's that lock it any differently then the ecm under normal driving.
    Plus under normal driving the pids dont even show its trying to go
    into lock up. I think there is another wire that im missing that needs to
    go to the ecm, besides the one brake switch that I allready have hooked
    up on pin 33 blue ecm. By the way what do the min tcc control and how
    dos it decide between min and max. Thanks for the input Ben
    Apr 2009
    613
    The only thing that sticks out to me is that all your MAP sensor codes are turned to no error reported. Why was this done? What is your map reading while cruising? I'm sure there is a load based tcc table that we don't have access to that may be not letting it lock up.
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Nov 2002
    Central Florida
    2,503
    Look at TCC_Mode PID in the table view of the scanner
    (can't plot, non-numeric value in many modes). If you
    see "--3--" the TCC is being held off by misfires, which
    are always aggravated (the detection scheme, not the
    reality) by a lightweight converter.
