ok, just a quick one, as i understand from reading the directions, i just wanna make sure i got this strait
i can setup the PE EQ for 12.20 afr, then as the boost comes up to 160kpa say 11.50
then as i hit around 200KPA i can hit 11.0...
the boost EQ table takes over, and does not add to the PE table already in place correct?
say i flatline the PE EQ to 1.20
then low boost i set the boost enrich table to 1.28 at low boost and then 1.33 for higher boost say over 14psi...
the richest EQ ratio will take over, no matter what table i am using or have filled out correct?
they are not adding into each other say 1.20 then in boost its adding another 1.28 or 1.33 on top?
just wanted to make sure
thanks !
