Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Ghost Cam Lope Tune
    Dec 2009
    So MD
    132
    Ghost Cam Lope Tune
    Customer asked for a simulated long duration cam idle. He liked it!
    http://www.youtube.com/watch?v=O45Nn...ature=youtu.be
    Jan 2013
    9
    Haha that sounds pretty good. What exactly have you changed? I've been playing around with mine,but I havnt had results as good as that.
    Dec 2009
    So MD
    132
    RAMJET GHOST CAM LOPE TUNE
    1, Goto Engine, Spark, Advance, Idle Adaptive Spark Control, Overspeed & Underspeed, P/N, Gear, & Coastdown. Enter ½ of highest RPM error constant value in first cell from 0. Interpolate from first entry to first constant value. Repeat for remaining tables.
    2. Goto Engine, Idle, RPM, Adaptive Idle Proportional Enable RPM Error.
    Subtract 10 from factory value.
    3. Goto idle Integral Enable RPM Error. Enter value 5 less than new Proportional value.
    4. Goto Proportional Airflow table. Multiply Normal values x 1.03.
    5. Goto Integral Airflow table. Multiply Normal values x 1.20.
    6. Goto Target Idle Speed table. Add 50 RPM to temperature stabilized idle speed cells. Copy same speeds into P/N cells.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Cool sound but how's the surge at a stop light?
    618/618 motor
    906/862 spray
    Dec 2009
    So MD
    132
    Not bad at the stop lights. It does shake a bit - enough to rock the car.
    Aug 2009
    Calibrating
    3,371
    This is a stock cam??
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Ben Charles View Post
    Indeed.
    618/618 motor
    906/862 spray
    Aug 2009
    Calibrating
    3,371
    Hmmm pretty cool
    I have played with the overspeed underspeed timing tables before to add in or subtract A LOT of timing below 75 rpm swings to do something similiar, but never on a stock cam.
    Problem is driveability usually suffers
    14 Gen 5 Viper
    Dec 2009
    So MD
    132
    No driveability issues! Any throttle application removes the timing swings.
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Roger Ramjet View Post
    How're you getting around that? Every now and then with a car that has a pretty aggressive spark correction setup has an issue.
    For instance, leaving a stop sign. Depending on where the spark control is at whenever you touch the gas, sometimes the car may leave at 18 degrees advance with the feeling of clean crisp throttle response. Other times it may leave at 6 degrees advance with the feeling of sluggish throttle response as it takes the ECM a bit to advance the timing back to cruise levels. Any help for that issue?
    618/618 motor
    906/862 spray
    Dec 2009
    So MD
    132
    I like to limit Throttle Area Rate Increase to 50% in gear 1 low RPM area. This also aids traction on A6 cars with that deep 1st gear.
    Feb 2013
    In Front Of You
    77
    can this be done to a ls1?
    67 camaro 6.0lq4 turbo build in process
    89 mustang coupe ls1 80mmturbo, holley dominator efi on e85
    02 lexus is300 lq4, cam,headers,fast 92 intake
    and no there isnt anything in my yard unmodified
    Feb 2006
    PAC NWest
    395
    I would like to try this.
    Can you explain #1 a little more clearly please?
    For 4 and 5, I have several tables, adjust all of them?
    Feb 2006
    PAC NWest
    395
    Mr. Ramjet?
    id like to try this as well but not really following along with #1, 4 and 5 as well, there are several tables. maybe the tables are different for a ls f-body?
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by hodge9386 View Post
    not maybe; it's definitely not going to be the same
    Steve Williams
    TunedbyFrost.com
    Feb 2006
    PAC NWest
    395
    could you make a suggestion as to which tables should me modified if any?
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    767
    Step 4..... Multiply Normal values x 1.03 is that only positive values or both the negative and positive in those tables etc.
    2017 Toyota Kluger - 10.1" Android Custom Head Unit, Rockford Fosgate Speakers, 85kg Roof Racks. Prev: 2009 Cammed VE SS Sedan, DOD Delete, 210/218 550', RAMJet OTR, HiFlowCats, IQ System, Amp/Speakers.
    Sorry to resurrect a dead posting, but I just came across this and think this would be pretty neat to mess with my friends. But as everyone was saying, can you clear up step one a little please?
    1
    Does anyone know how to get a hold of roger ramjet?
