Results 1 to 17 of 17
Thread: Logging Fuel pressure with AEM 0-5V output
    Nov 2008
    Hampton, VA
    75
    Can anybody tell me how to setup the PID in HPtuners for logging fuel pressure from an AEM fuel pressure gauge with the 0-5V output? I see the autometer PID in hptuners already but none for AEM. Will the autometer one work?
    Dec 2008
    on the Dyno
    1,825
    You will probably have to use a custom PID with a correct transfer function. You'll need what PSI range the sensor reads and at what voltage output for those readings to generate a transfer function.
    Located in Central Kentucky
    ShorTuning
    Jan 2013
    19
    I am using an Autometer gauge and was wondering the same thing. Where would someone find out that information? I am assuming contact the manufacturer.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    For Autometer:
    V/0.04 - 12.5
    Not sure what range the AEM is. Find out and I'll give you the transfer function.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Nov 2008
    Hampton, VA
    75
    Just for kicks I loaded up the Autometer PID and it seems to be right on with the readout on the gauge inside the cab. It is a digital gauge and the FP is fairly steady so pretty easy to compare the two in real time. Should I just roll with this or not?
    Aug 2006
    5BA8
    3,253
    Could be the same sending unit.
    Edit: I found a picture of it, and it does not look like the same sender. The gauge is 0-100 psi, not sure if that is the exact operating params of the sender though, could not find that info in a quick search. It is 0-5v though.
    You could always rig up a pressure reg, and do a 0-100 psi voltage check.
    EFI specialist
    email=[email protected]
    Mar 2008
    St. Louis, MO
    4,860
    Fuel pressure sensors are almost exclusively 0.5-4.5v operating range (but still get categorized as 0-5v since they operate in that range). The AEM probably uses 0-100 as well. The only other common sending unit is 0-150psi. That one also uses 0.5-4.5v readable range.
    Dec 2008
    on the Dyno
    1,825
    I know the resolution wouldn't be that great because it is a much higher pressure sensor but has anyone tried using an old A/C pressure sensor as a fuel pressure sensor? I've been wanting to try it for a long time and just have never gotten around to it. I have the transfer for a stock A/C sensor as well.
    ShorTuning
    Mar 2008
    St. Louis, MO
    4,860
    Fuel might damage the sensing element.
    That's pure speculation.
    Dec 2008
    on the Dyno
    1,825
    Well I have a few spares and pigtails so I am going to give this a try.. I'll report my findings. Old junkyard A/C pressure sensors will be cheap to get and alot cheaper than the AEM or Autometer sensors.
    I just wonder if it'll hold up to freon if gas will be that much worse??? Guess we'll see.
    ShorTuning
    Sep 2010
    FL
    374
    My AEM fuel pressure sensor is the 0-100 PSI one, and the analog formula for it is:
    (V*25)-12.5
    The inverse of that is (V/.04) - 12.5. So they are the same.
    Jul 2011
    24
    Exactly what I was looking for in my search, except I didn't notice the - at first. Kind of threw me off as I was using + 'doh.
    Jan 2012
    Maitland NSW
    61
    I use an ls1 oil pressure sensor, works perfect for me, i made an extension harness to plug into the engine harness and made up some adaptors to connect it to the fuel line, then just go into scanner and pick engine oil pressure abd log away
    Sep 2011
    Portland, OR
    518
    This makes perfect sense! Nice job. I was thinking the same except I'll have to add those wires to my harness. The 99 Camaro just had a gauge, the PCM didn't know oil pressure.
    Ron
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Jun 2006
    San Diego
    134
    Quote Originally Posted by LSxpwrdZ View Post
    Whatever happen with this James?
    Got GEN II-IV LSx or GEN V LTx parts to sell? Post em completely free on LSx LTx buy/sell/trade Facebook group. Invite your friends.
    https://www.facebook.com/groups/169854669867850/
    DO YOU OWN A FORD, DODGE OR GM ALLOYTECH VEHICLE AND GET A MESSAGE SAYING "VALIDATE CHECKSUM FAILED. YOU WILL BE UNABLE TO SAVE OR FLASH THIS FILE." IF SO FOLLOW THE LINK BELOW.
    http://www.hptuners.com/forum/showth...lash-this-file
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by fullthrottle View Post
    Never ended up doing it with all the other projects that took priority over it. However I did find the transfer function for the Fbody AC pressure sensor. I'll just have to dig it up.
    ShorTuning
    Jan 2015
    Arizona
    452
    been 7 years... ever get a round to doing it?
