Results 21 to 40 of 41
Thread: Relay to retard timing for nitrous??
  1. #21
    Nov 2007
    MI
    686
    Quote Originally Posted by backchannel View Post
    For extra fuel with nos when iat resistor is used, set inj flow rate vs iat. I used .86 at 50C> [ used a resistor that read 60 C in the scanner]
    This is for a dry setup
    ah I see. With a wet kit I would just bake the fueling error introduced by iat into the fuel jet...using a window it's not a problem. Not a fan of dry kits, nor have I set one up so I can't comment on that.
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
  2. #22
    Feb 2007
    Calgary
    155
    Quote Originally Posted by GPGTP View Post
    I posted before realizing the op was using wet system.
  3. #23
    Jun 2012
    9
    I have been thinkning about using this on my G8. I have the Nitrous kit just scared to use it until I understand how to tune correctly. The wifey will not be happy if I damage my car.
    Just to be clear. This should not effect fueling on a MAF only tune but will affect an SD+MAF tune or SD only?
    I am still learning so....
    How is it effected in the VE tune? What map references the IAT for fueling.
  4. #24
    Sep 2008
    1,668
    If you're nervous about setting this up in the tune, make sure you keep the solenoids unhooked when you first try it. First just hook up the relay to the IAT and watch your timing as you turn it on and off...you'll see the spark cut immediately. After that, play things conservative with the nitrous and fuel jets until you know where you're playing as you're adding more power.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  5. #25
    Sep 2008
    399
    So what exactly needs to be done to the fueling for the iat range specified by the resistor? Or does the tune not adjust fueling based of iat?
  6. #26
    Aug 2009
    Calibrating
    3,378
    With nitrous your IAT's should dramatically lower, just set up the tune to pull timing if it gets hot or add fuel.
    SD references IAT, in which it would add fuel b/c of the cooler IAT's
    MAF IAT is not taken into the calculation.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  7. #27
    Nov 2007
    MI
    686
    it affects a/f when in speed density, but only when the relay is active, the relay is only active if your spraying....make up the error with your fuel jet.
    If your dynamic airflow setting is stock then it's maf only above 4K anyway.
  8. #28
    Dec 2008
    on the Dyno
    1,825
    If we had access to all of the E85 tables we could use that for nitrous fueling and timing... EFILive uses it that way.
    Located in Central Kentucky
    ShorTuning
  9. #29
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Very cool tech info. I wish we had subdivisions of the forums subjects for like, N/A, FI, and Nitrous. That way we could sticky pertaining info in each category.
    618/618 motor
    906/862 spray
  10. #30
    Nov 2007
    MI
    686
    Quote Originally Posted by LSxpwrdZ View Post
    not a bad idea. I assume you trick the pcm using the alcohol sensor?
  11. #31
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Yes, but you need to be able to generate a reliable frequency from 50 to 150Hz with a microcontroller.
    HP Tuners doesn't have all of the parameters yet to enable Flex Fuel, though, so we can't do much right now with it.
    http://www.dsxtuning.com
    Just say no to bull s***.
  12. #32
    Advanced Tuner Justinjor's Avatar
    Jul 2011
    Tampa, FL
    275
    I run mine through the ECT. Resistor set to 237*. Best part about it is the visual cue via the coolant temp gauge that tells me the car is for sure pulling the timing.
    2020 Mustang GT Daily driver
    |Hellion Sleeper|10R80|Full weight, full exhaust, BABY seat in the back|
    8.3@167mph
    2014 Mustang GT
    |Hellion TT|Powerglide|Ignite114|
    6.87@200mph
    Jordan Performance and Racing
  13. #33
    Quote Originally Posted by Justinjor View Post
    Very nice!
    2011 CTS-V w/FRA, bolt-ons & flex
  14. #34
    Nov 2007
    MI
    686
    excellent; however, I will most likely never use this as I like using E85 for boost way more.
  15. #35
    Any update to this? I've got plenty of injector on my setup and was considering running a dry system and having the computer add fuel if there was a workaround to do so in an E38 computer.
    Matt
    GM World Class Technician
  16. #36
    Jun 2010
    Fort Walton Beach, FL
    7
    Same here, I had been running a 150 wet shot, but since I just installed a dual 267 pump Fore hat and 95 lb injectors, figured it be simpler and alot safer. Will give the IAT resistor mod a try.
  17. #37
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    I would add 1 note, on the relays I installed I wired them to bypass through relay when nos is off, and to stack a resistor when nos is activated. I am in south louisiana and iats at the track can be 120 already, so by stacking I know I am not just pulling 8* from a stock map, but pulling 8* from what is already pulled. I have seen the setup described and was only pulling 1-2* over what had already been pulled, and motor was pinging away. Not very good. just my .02
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    Shop Owner
  18. #38
    Dec 2013
    Southern IL
    73
    Quote Originally Posted by mbray01 View Post
    This is going to save me a lot of money and work. Could you elaborate on the stacked relays? Ant info would help.
  19. #39
    Dec 2013
    Slidell, La.
    1,015
    not stacked relays, but stacking a resistor on top of iat sensor using a 5 pin relay, in closed position it sees the iat only, in open or armed position it sees the iat plus the resistor. it requires learning what the iat resistance vs temp is and getting a resistor that would add "x" amount of degrees to achieve the amount of timing you want to retard. Of course you will have to play with the iat timing table as well if you are spraying a lot of nitrous.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
  20. #40
    Nov 2021
    Colorado
    53
    Why not use a potentiometer (variable resistor) to be able to get at your exact ECT on the table ?
