This is my first turbo car and could use some help with the VE table and timming. The car starts and cruises great, I just started tunning the VE table and havent got very far. As soon as I get above 115 kpa it goes way rich, so ive slowly been leaning out the ve table. Ive leaned out the ve table alot and its still rich so im thinking im not running enough timming. Will running not enough timming cause a rich afr? Is thers a cutoff point where running not enough timming will cause the engine to fall on its face and go way rich or do I need to keep leaning the VE table
My setup
1964 Nova
stock Lq4 with headstuds and mild cam
twin precision 6265 turbos
80lb injectors W boost reference FPR
pump gas
2 bar SD tune open loop
