Results 1 to 5 of 5
Thread: MAF possible with 2 bar tune?
    Mar 2009
    44
    The vehicle is my wife's 2001 Yukon. Combo is an L33 5.3 with a small cam(216/224 .551/.551 115 LSA), and a MP112 Magnacharger with a 3.4" pulley. About 8 pounds of boost. This setup came out of my truck, but formerly had a 2.8 pulley, 92mm throttle body, headers/ORY, etc, and a MAFless 2 bar tune.
    Now it's back to manifolds & cats, and a stock throttle body. I want to run the MAF because this vehicle will be towing a trailer through the mountains, and will likely also travel the Alcan highway.
    Right now I have it running the MAF sensor on a 2 bar tune. But I'm having a really hard time with inconsistent fueling. The PCM commands PE when I want it to. It commands BE when I want it to. But my actual AFR often times will not achieve the desired AFR. Sometimes it's just fine, and other times it stays lean.
    Should I give up on this and just put the 1 bar MAP sensor back in, and run on a 1 bar MAF tune?
    Mar 2009
    44
    Bump!
    Can I run the MAF sensor with my 2 bar?
    Aug 2009
    Calibrating
    3,373
    Some OS you can I do on my 2002 411 ECU, and some its completely coded out, best thing to do is try it and see then report back.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Quote Originally Posted by AKlowriderZ71 View Post
    I am useing it on my 0411 box with 02 Escalade file, so far so good. not completly finished tuning yet.
    Mar 2009
    44
    Bill emailed me explaining that a MAF was never intended to be used on the custom 2 bar OS, and if I intend to use a MAF, he recommended not using the custom 2 bar OS.
