Results 1 to 6 of 6
Thread: Tuner Lock
    Tuner 1FastLS's Avatar
    Mar 2005
    Warrenton, va
    62
    Tuner Lock
    Well got a call from a guy i had done some work on their car tuning, he called and said his file was locked i have never locked any vcm files ever.
    So i get laptop out and every file appears to be locked, not sure why so my understanding is you just click Auto lock all to unlock ?? and save ?? Have done this several times with no luck to unlock my files, do i need to be connected to a car i do have cable attached but not to car ???
    But files will not unlock any help would be great thanks
    Tuner 1 day
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    set it so it no longer tunerlocks all files, then you need to go into each individual file & unlock the ones you want unlocked.
    Mar 2005
    Warrenton, va
    62
    so just click on (tuner lock all ) and it should no longer lock files ?
    But when i do that then i save the file and do it individually close the vcm suite go back in they are locked again ??
    Tuner 1 day
    HP Tuners Support
    (foff667)
    28,268
    The files themselves will stay locked until you go in an unlock them.
    Mar 2005
    Warrenton, va
    62
    Ok thanks Bill will do
    guess you need to be attached thou i went threw the files and unlocked them all saved everytime then closed suite then open it back up and then the showed locked again i will try it while attached to vehical thank you for your time
    Tuner 1 day
    HP Tuners Support
    (foff667)
    28,268
    Nope, no connection necessary to unlock a file.
