Results 1 to 2 of 2
Thread: Ported TB - Fuel Economy Drop
    Nov 2012
    41
    I just put on a ported TB on my L98 6 litre.
    Improved throttle responce. Idle and drivability with my cam, but the fuel ecconomy has gotten worse by almost 2litres/100kms.
    Any ideas on how to get it back? nothings changed except the ported tb.
    Also would a hybrid openloop at low rpm / closed loop at higher rpm setup as mentioned in the other threads for the gen 3 work on the gen 4 pcm?
    Nov 2009
    All Around
    3,149
    larger cams have poor efficiency you know, check your fuel and ignition are cruising area under .64 cylinder airmass g/cyl
