I'm trying to disable AFM/DOD and Tq Mgt on a friends 2013 Camaro L99 A6. I'm searching this forum and this what I've come up with.
Will this get me there?
Engine>Fuel>COT, Lean Cruise. Master enable/Disable or by gear (1=disable 0=enable?) I assume 1 = disable because everything 3-6 has a 0 in stock form.
Transmission>Torque Management, set stall torque mgt enable to 8192 set disable to 8190. set tcc limt to 6042.
then go to auto shift properties- shift pressure then shift pressure other, set discrete shift torque mode to disable.
Engine->TM->General:
Set All Max Torque gears to 6042, all cells.
Trans input and output max to 6042.
Brake Torque Limit to 6042, all cells.
ETC Limit, set to disable.
Sarge
