Has any one had any trouble running tr-6 plugs with 0.35 gap. useing ls coils part number 12570616, D1SC blower 14 -15 pounds of boost. 9.3 compression. under load it starts to back fire out the exhaust then just looses power let off gas comes back to life. buddy of mine said he has had this happen on a few cars and had to bring the gap down to .025. I have never had this happen at this boost level, he said its rare but if it comes up on boost to fast with some combonations it has happend. on the data logger when it happens nothing shows up. fuel pressure stays good and injectors are only at about 20 percent duty when it starts starts to happen. air fuel still reads about 11.5 and the plugs look good even tryed a new set. Thanks for any input.
engine is 383 lt1 9.2 compression camshaft is 218/ 230 at 50
backfiring starts to happen about 2400 rpm at 150 kpa the more you lean into the throttle the worse it gets until it just quits, if you ease off the throttle ie, back the boost down it starts to run fine again
