Tuned the MAF & VE via wideband but since putting it back to normal in closed loop etc....... noticed various issues.
So I've switched to just running MAF with LTFT turned off to get an idea of the STFT gear.....
STFT's are around -2 to -3 in the lower maf hz area's, going to -5 etc in the higher 6000-7000hz area on the maf and then dropping down to like -2's ......
My question is this:
What do I need to change in the closed loop to make the O2's bounce quicker to tighten the STFT's up....... I dont want to do it via the MAF because I know it's tuned right from my wideband.......
Would this be eg lowering. Closed Loop Proportional - Airflow Mode? Or is there a better way.
Closed Loop Intergrator Delay? Lower that?.....
Hopefully someone will have some advice for me this time on this thread....
