P1336 CASE Learn revisited
Hi guys,
I'm relatively new to the forum and i have read through all the CASE learn threads that i could find but i cant seem to find a similar situation to mine.
My motor is a stock LS1, Corvette C5 2003 model and i have a P1336 code popping up. Now, i run the case learn and as far as i can see, its a text book execution. My CASE learn process goes EXACTLY like it does in HPtuner's instructional video..
http://www.youtube.com/watch?v=EVKxAt39ydg
There is one small difference though, my TPS% is always at 3%. It never goes to 0% like in the video. But, VCM Scanner says nothing about this. It allows me to do the test and doesnt give me an error. I also dont have any codes popping up relating to this.
I must be doing something wrong but according to the instructions and hell, even the demo video, i'm supposedly doing everything right. I even get the same result at the end other than the fact that the error is always reappearing. Could it be that i need a new sensor?
*** Update ***
Never mind, it finally just worked. After literally the 17th time i executed the learn procedure, it finally stuck. So there you go, if anyone out there gets into the same situation, just keep trying the test. It will eventually stick...
Reason: Updated information
