Results 1 to 6 of 6
Thread: Scanner MAF Reading 0.59g/sec in SD mode???
    Nov 2012
    41
    Hi
    i am running a custom os and doing a mafless tune.
    I have disconnected the MAF with a mafless otr but in the scanner it is showing the MAF running 0.59g/secs.
    I though it should be 0 g/secs. Is this normal? Any procedure to reset?
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Don't log MAF, it's pointless if you failed it properly
    9 sec Montecarlo SS
    Nov 2012
    41
    but shouldn't it read 0g/sec?
    Nov 2009
    Pegasus Galaxy
    919
    It should, but it does that sometimes. It doesn't matter.
    If you want to reset it, hook the MAF and enable it in the tune.
    Open ignition key and scan, don't start engine. It will read 0 HZ and 0 g/sec
    Close scanner and turn key off.
    9 sec Montecarlo SS
    Nov 2012
    41
    Cool thanks ill do that.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    On some cars with different pinouts they sense the MAF as being open circuit or dead and defaults to whatever resistance they have through the 5V reference. Sometimes they're zero, sometimes they're an obscene number. Nothing to worry about.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
