Results 1 to 16 of 16
Thread: help with ls2 running lean please!
    Apr 2012
    10
    hi guys, i have a 2005 hsv clubsport r8.
    It runs the ls2 in it and have done long tube headers, full stainless exhaust, OTR intake, has a large cam, valve springs, lifters, pushrods etc, factory ecu and fuel system. About 580hp.
    The car had been running fine for 4 months since it came back from the dyno the first time but then one day i noticed it to be running pretty shit, so i put the laptop back on it and noticed the the stft were getting up in the 30s and and ltft were getting up to 20. i added more fuel into it but had to put mass amounts in to drop the fuel trims and then next time i drove it the fuel trims were right back up. every time i add more fuel into it nothing happens and continues to run lean.
    Since this issue has started i have and the injectors checked and cleaned, new fuel filter, checked fuel pressure (60psi), new o2 sensors, checked for vaccum leak, charge battery and check voltage from alternator and check all earths i can find.
    When the car came back from the dyno the first time the injector duty cycle was 88% at full throttle and now its 99% and running very lean, but the fuel trims are highest at around 3000rpm+ which is where the cam starts to turn on.
    I really need help as i have spent weeks tryna figure this out.
    Any ideas guys? thanks, mitch.
    Nov 2009
    All Around
    3,149
    did you upgrade your injectors?
    also in diagnoses have your limited your max airflow vs rpm and ignition.
    also check your MAF
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    If you're sure you've got plenty of rail pressure, that exhibits the classic symptoms of injectors failing. You running on E85?
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Aug 2010
    Roswell, N.M.
    1,956
    Might wanna post a tune and log, and tell us what kind of injectors you're running.
    618/618 motor
    906/862 spray
    Tuner Mez's Avatar
    Nov 2008
    Austin, Texas
    163
    Vacuum leak. You said you checked it, but keep looking.
    Also, check for exhaust leaks ahead of the O2 sensor.
    2014 Corvette, Z51, 3LT, 7-Speed, NPP, 2 tops, Exposed Carbon Fiber roof, FAY, Laguna Blue, Kalahari, Museum Delivery.
    Apr 2012
    10
    the injectors are the stock standard ones but since having the issues they have been cleaned and tested at a injector shop and they are working fine. I dont think the injectors are too small because it ran 3 or 4 months fine then all of a sudden went bad and started going lean? and nope just pump gas 98. il try put up a log later on today. i will check for intake and exhaust leaks more and get back to you. thanks!
    Apr 2012
    10
    here is the current tune
    Apr 2012
    10
    after the first log was done i added fuel in or removed as required. so here is one and about 30mins later the second log was made
    Apr 2012
    10
    so basically since the first tune of coming back from the dyno nothing im aware of has changed tune wise other than i keep putting fuel into, the numbers in the log above arent as high as they sometimes get too but it seems to be slightly incosistant.
    Looking at your logs it looks like a vacuum leak to me, your LTFTs are high but drop off as RPM and MAP rise.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
    Apr 2012
    10
    oh yea, that makes sense. i have looked for leaks but cant find any as of now? what is the best way to check for leaks? is there a certain way of doing it that is easier/better other than just physically checking?
    Apr 2012
    10
    hi guys, ive spent all day trying to find a vacuum leak and have found nothing. i tried using smoke machine, taping up throttle body and putting compressed air in a vacuum hose, propane while running, engine start while running, carb cleaner while running and hooked up a vacuum gauge as well as factory map.
    But what i did notice whilst looking over the logs was that bank two seems to be pretty good and the fuel trims only come on when bank one changes excecivly. could this mean anything? thanks
    I'm no expert, just pointing out what I saw in the logs but maybe it has a manifold gasket sucked in in the valley, that may explain one bank being more affected than the other.
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    Quote Originally Posted by Mez View Post
    What he said ,
    Intake gaskets , even os2 sensors not being tight correctly
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Jul 2012
    Italy
    219
    try to swap O2 sensor.
    Any luck Kiwi?
