how i turn off the traction control system
on silverado 2012
on silverado 2012
i have 2 traction control , 1 with button & 1 without button , its come on dashboard when the car slip even i off traction
Attachment 37605
this what i mean ,, can any one help with that
stabilitrak is never 100% disabled
The most hated, make the most power.
93 Ranger. 5.3 D1X. 1069hp.
on my 2010 silverado, i have to pull the number 9 fuse {abs} this gets around it 100%. downside to that, you lose the abs all together.
if you hold in the traction control button (under the hvac controls) for 5 seconds it will shut off both traction control and stabillitrack.
no. see above. govt mandate ruins your fun.
is that only on the pickups? i can shut both off on a '12 avalanche..
first push - only traction control
Attachment 37991
hold for 5 - both traction and stabilitrack
Attachment 37992
now, go play around in the rain. go half to 3/4 throttle in first around a corner. listen and feel what happens. stabilitrak kicks in.
a way around it without pulling a fuse. shut them both off. {indicated} go wot.
