Results 1 to 18 of 18
Thread: Best injectors to get with known data?
    Feb 2008
    248
    Looking for injectors that will work with an 04 gto ls1. What are some injectors that I can buy off the shelf that have known data for the ecm? I'm really not after a partcular Lb injector.
    I know the bosh 0280155868 36lb injector (that is also made by fast) has injector data available. If i needed something bigger, do I have an alternative other than ID injectors?
    Please assist.
    2004 GTO LS1~HP Tuners~AFX W/B~PRC 227 heads~.644/.598-231/234-111(TQV3)~Kooks 1 7/8 headers~Stock injectors~Fast 102 LSXR Intake~Fast 102 TB~CAI cold air intake~Yella Terra Roller Rockers~Fast Fuel Rails~
    Dyno's are for sissy's, See you on the street.
    Aug 2009
    Calibrating
    3,373
    42 bosch are good injectors and data is available
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Dec 2004
    Laurel, MD
    1,020
    other stock injectors from bigger platforms, i.e.: z06, zr1
    Feb 2008
    248
    Do you happen to have a part number or a link to the injector data? Thanks a lot for posting this info up. Is this the correct part number? The green tops commonly used in the mustangs?
    0 280 155 968
    Feb 2008
    248
    Im possibly looking to supercharge on top of my heads and cam. Who makes the ZR1 injectors and where can I find them? I'm assuming the injector data for the ZR1 injectors would be in a Zr1 PCM?
    Thanks for the help so far...
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Siemens Deka 60 lbs, good injectors and the data is available. They run and idle very good even in stock engines.
    9 sec Montecarlo SS
    Feb 2008
    248
    I would love to run the seimens deka 60's. I did a search and could not find the data. Do you thing you could post a link. If I could get the injector data for these that's all I would need and it would seal the deal for me.
    Nov 2009
    Pegasus Galaxy
    919
    The data is not freely available. I have it because I bought Greg Banish's DVD. I can't send you the spreadsheet with the info for obvious reasons
    If you don't find one in repository (which I doubt) I can send you one of my personal tunes and you copy over the injector data (unless Greg says otherwise)
    9 sec Montecarlo SS
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by redhardsupra View Post
    Winner winner chicken dinner.
    If the LS9 injector can't handle it, I go straight to IDs.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2008
    248
    Does anyone have a part number for the injector in the Zr1? I would like to make sure I get an authentic injector.
    Nov 2010
    35
    Check out the dealers, people who work with and use Ansu and equip. By far the best in the market. Ansu is the benchmark that most try to achieve but not one has been there yet.They tell everyone else what to do.
    98 s10 5.3 5spd.
    Feb 2008
    248
    Can you define ANSU for me? Google did nothing.
    Aug 2009
    Calibrating
    3,373
    That data is copyrighted I believe?
    14 Gen 5 Viper
    Nov 2010
    35
    Quote Originally Posted by TDCRacing View Post
    OOPS, sorry, Asnu. May not be as easy as just buying your basic siemans, id's or bosch, but worth the effort.
    98 s10 5.3 5spd.
    Feb 2008
    248
    Quote Originally Posted by 98S10 View Post
    thanks.
    Feb 2008
    248
    Would injector data from the stock zr1 tables be directly transferable to my pcm as long as the measuring values were the same? Anyone have that date?
    Dec 2004
    Laurel, MD
    1,020
    depending on the type of computer you got in comparison to zr1's, so probably not. but it's very easy to convert one set of data to another, they're all the same model, just different range/resolution of data.
    Feb 2008
    248
    It's a ls computer out of a 2004 gto with an ls1.
    I'll have to look in the repository
