Results 1 to 11 of 11
Thread: 2005 GTO SD Tune, Hesitation on tip in
    Apr 2009
    32
    I have a GTO that Im running a SD tune. I have a hesitation right off idle on throttle tip in. What do i need to adjust to cure this?
    Ray
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    MOAR FUEL!!!
    Is it when you hammer the throttle or as you ease into it?
    618/618 motor
    906/862 spray
    Tuner Mez's Avatar
    Nov 2008
    Austin, Texas
    163
    Quote Originally Posted by rtkjadams View Post
    Ray
    Post scan and tune please.
    2014 Corvette, Z51, 3LT, 7-Speed, NPP, 2 tops, Exposed Carbon Fiber roof, FAY, Laguna Blue, Kalahari, Museum Delivery.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by Mez View Post
    What's the fun in that? We are supposed to blindly guess!
    http://www.dsxtuning.com
    Just say no to bull s***.
    Potential Tuner slow ride's Avatar
    Dec 2012
    6
    The OP is a friend of mine that is helping me tune my car. We live an hour apart so I wasn't able to make it over to his place for a scan. We will do some scans tonight and post the results. The issue is on a quick "stab" of the throttle. A slow steady rev increase is smooth.
    Mar 2008
    St. Louis, MO
    4,860
    You probably need more fuel in the high MAP, low RPM part of the table. However, it's hard to tell anything without a log or even a tune file.
    Aug 2010
    Roswell, N.M.
    1,956
    ^ there are two solutions to that.
    1. More fuel needs to be added to the low rpm/high map side of the VE table.
    Most people never collect data from that part of the table unless they have a load bearing dyno or way too much time on their hands.
    2. Additional transient fueling needs to be introduced to keep the lean spike out of the rapid throttle transitions.
    Lately there has been a slew of people having problems with transient fuel and SD. Search some of the other posts in this section. You'll see you're not the only ones.
    Edit: looks like I was beaten to it
    618/618 motor
    906/862 spray
    Apr 2009
    32
    here is the log and file
    Apr 2009
    32
    That is the tune we are running.... We orginally got a SD tune from a tuner but I wasn't able to load it to the car, so I thought I copied all the files over. I guess not...
    Ray
    Apr 2009
    32
    How's this? I guess we have to relog the car again... Can you look over to see if anything sticks out???
    Aug 2010
    Roswell, N.M.
    1,956
    Holy shit.
    618/618 motor
    906/862 spray
