Reason: need to edit.
99 silverado 1500 5.3, 30 over, all new ported, polished, and milled heads 30 thou, 220 226 custom BEI cam. 2" intake valves, ported & polished TB, Long tube ceramic coated headers, magna flow cats, y pipe, 3" magnaflow, vera ram air intake, I6 TB stall, All new Drivetrain, 3 Trans coolers, Auburn E-Locker, 4.56 gears, Throttle body bypass, Flex-a-Lite E-Fans, LS1 e-fan harness, ASP Under Drive Pullleys, HP Tuner Pro. 1 Bar MAP SD OS upgrade. Amsoil EA Bypass Oil Filtration system.
