im trying to teach myself tuning so help me out here guys. the car is a 06 pontiac solstice 2.4 has a hahn stage 3 turbo @ 13lb hoping to get to 15lb. it has 60lb injectors,2bar map, and a devils own meth injection kit with meth coming on at 10lbs running the biggest meth jet in the kit.
ive attached a couple log files using different configs, you can see the KR that im trying to get rid of. Heres my theory tell me if im crazy, since its getting KR in certan areas should i go to those areas in the tune and pull the amount of timing that the car is pulling?
if so how should i go about it? im finally starting to understand a little of the program so bare with me
thanks in advance
