Results 1 to 5 of 5
Thread: Help with lambda error
    Jun 2010
    Alabama
    21
    I have something going on with my lambda error equation that shows a result of something around 1400-1500% error. Can anybody help me figure out what is wrong here? I have attached some screen shots and my scanner config.
    Jun 2010
    Alabama
    21
    actually that was the log that I posted. Attached is the config.
    Feb 2006
    central michigan
    349
    your aux.20003 is the wide band reading in afr not in lambda . so your pid for lambda error is 100 x afr minus lambda devided by lambda. that wont work.need a pid for lambda---wb/stoich.
    Jun 2010
    Alabama
    21
    ok. i see why that wasn't working now. does the set up in the pictures below look correct now?
    Feb 2006
    central michigan
    349
    no.you still don't have the wb reading in lambda.see this thread---http://www.hptuners.com/forum/showthread.php?t=26134&highlight=plx+lambda . or use the search function.
