Results 1 to 6 of 6
Thread: Where did I go wrong (WB O2)
    Oct 2010
    NE Iowa
    14
    I have been working on this for a while.
    Searched for hours and tried to fix it with no luck.
    Please look through my files and let me know what I did wrong.
    Attachment 37152
    Attachment 37153
    Attachment 37154
    Attachment 37155
    Attachment 37156
    Only running one NB O2 and the WB O2.
    No MAF (not fully tuned out yet)
    No EGR (using for WB O2 - pin 55 egr valve position)
    Checked Ground offset as well. ( .04 difference)
    Everything I'v done gives me the same results.
    Maybe I calibrated it wrong...
    Maybe I didnt' program it through LM Programmer v3.31 right...
    Past frustrated...
    Please point me in the right direction, advice...link...
    2016 Jeep Wrangler, 3.6 Pentastar, 6 speed, 3.73 axles.
    Oct 2010
    NE Iowa
    14
    How can it give me a higher than 20.9 while its running?
    Feb 2006
    central michigan
    349
    nobody can see your custom pid's unless you also post your vcmscanner.cfg file.did you by chance read this thread ?http://www.hptuners.com/forum/showth...&highlight=egr
    Oct 2010
    NE Iowa
    14
    Thanks for the reply but I posted 3 files and 2 pics...Basic Config.cfg. let me know if you can't see or load it.
    I read that thread multiple times along with many others.
    My wideband formula through the EGR is ([PID.2811]/.5)+10 and I've tried many similar while changing the LC-1 programming to match.
    my ground offset is .03
    I recalibrated the sensor and sensor heater. dead on 20.9 (I'm at 7350 feet altitude)
    As soon as I start the vehicle it shows an AFR of 23:1+ and 4.97 volts at the EGR position PID in the table. While using logworks software through the computer it shows an AFR 28:1+ but Im using a serial adapter so that may be why its off so much in logworks. The ERG wire while its running shows 5 volts exactly with no change.
    Feb 2006
    central michigan
    349
    I see the three files. but your custom pid's are in the vcmscanner.cfg file that you did not post. look in documents/hptuner/settings/vcmscanner.cfg.doesn't matter now that you posted the pid.you may actually be running lean enough to max out the wb at 5 volts. as a way to confirm,decrease your injector flow rate by 15% and see what that does to the wb output.
    Oct 2010
    NE Iowa
    14
    I did as you suggested and it did drop. Should have thought of that. Thank you. On a stock tune for a 2001 silverado it shouldnt be that high. Ill find the source though and post a solution so its here if needed. Thanks.
