Ive been trying to set up my wideband through the 0-5v ECM input from the high pres. side a/c sensor. I have read about dozens of people doing this on other GM vehicles. I added A/C pressure to my table just to watch the readings, and it is always stuck at 184.92psi whether the a/c is cycling or not. The value never changes, which means if I did happen to run my wideband analog output thru this pin it would be worthless. Why has this worked for so many others, but VCM Scanner can't read/interpret the A/C pressure voltage coming through? I have even put a voltmeter to the output wire on the sensor and it varies from .88v up to 2.0v when the compressor cycles, but none of this is seen or recognized through the scanner when its happening... Seems like there is a bug in the software thats hanging up the reading. what is the most current beta?
