Results 1 to 19 of 19
Thread: lean spike at cruise
    Apr 2012
    Houston Texas
    21
    I have a 2008 C6 Corvette W/auto. 416CI ls3, 3800rpm stall, 102 intake, full exhaust, injectors, etc.
    The car has a len spike at cruise and I just cant find what is causing it. I have checked all my ground wires and attached another ground from the battery to the engine block. Under acceleration the car is perfect. I have attached a scan and the tune.
    2008 C6 / A6 coupe blk LS3
    CAI, AR headers, x-pipe, magna flow, no cats, cam 243/259@50 625lift 113 LSA, circle-D 4000 tripple disc stall, LSA heads, 3.42 Z06 diff, F55, 416CI, dewitts radaitor, P-fadT mounts, electric cutouts 275/35-18 fronts 295/35-18 rear, 102 fast intake
    Apr 2012
    Houston Texas
    21
    anyone have any ideas?
    Aug 2009
    Calibrating
    3,373
    Yea both your LTFT's and STFT's are both lean, turn off the LTFT's in the tune and then your STFT's will be way off. Dial in the STFT's and you will be good again on AFR.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Apr 2012
    Houston Texas
    21
    Quote Originally Posted by Ben Charles View Post
    Like this? Is this what is causing the lean spike/miss?
    Jul 2012
    Italy
    219
    1) do not use the cruise for this type of verification
    2) the maf is around 3400hz, try to increase in that range the maf of half% to ltft and see if you note some improvements
    Apr 2012
    Houston Texas
    21
    Last night I went through the wiring with a meter and checked everything. I also made the suggested tune corrections but the lean spike was still there. It was not as bad but it was 40* this morning and it seems to be worse when it is hot.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Try cutting your Closed Loop Proportional or whatever it's called in half. Closed loop will swing wildly on some setups, and it can be exacerbated by poor quality injectors. Reducing the proportional gain can deaden how hard they try to swing.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Apr 2012
    Houston Texas
    21
    Love the Clutch! We just received the first tripple disc for the ZL1 Camaro. The factory clutch lasted 6 passes before it went up in smoke. They have sent out one other clutch to some guys in FL but they still don't have it working right. It took some machine work to get it to work for us but we did it and it works great.
    Apr 2012
    Houston Texas
    21
    The shop worked on the car all day yesterday and they are telling me they think it might be an injector. They want me to send all the injectors off to be tested. The injectors are only a year old and they are ZR1 injectors. Does this sound right to you guys? The car does drive better and the spike/miss is much better but still there.
    Aug 2009
    Calibrating
    3,373
    Did you ever adjust the MAF curve?
    14 Gen 5 Viper
    Apr 2012
    Houston Texas
    21
    Sorry I did not download the current tune. It was very late when I got home and I had to take the airboat with me to work today because I am leaving for the coast.
    What did you see in the MAF curve that looks wrong?
    Jul 2012
    Italy
    219
    is the maf curve stock? You need to tune it right according to ltft (not at wot) or wideband
    Mar 2008
    St. Louis, MO
    4,859
    Run the car in open loop and see if it goes away completely.
    Apr 2012
    Houston Texas
    21
    I have people telling me that my miss is caused by airflow into my cold air intake???? I did install a small plate trans cooler in the bottom opening of my front bumper. The cooler takes up about half of the opening.
    Apr 2012
    Houston Texas
    21
    Ok here is where I am at right now. Last night I cleaned the Maf and my cold start issue went away. The car did not miss that bad on the way home yesterday when it was 78* outside but this morning when it was 50* outside it missed all over the place when I was at light throttle. it does it real bad in 6th gear 60-80mph and it is random.
    Mar 2008
    St. Louis, MO
    4,859
    Give it a shot.
    Apr 2012
    Houston Texas
    21
    Give it a shot.
    Tried it and the surge/miss/buck, what ever you want to call it did not go away.
    Mar 2008
    St. Louis, MO
    4,859
    Do you have a log while in open loop?
    Apr 2012
    Houston Texas
    21
    No
