Trying to tune a 2011 Camaro and a message apears. help.
disconnect battery for 30 seconds & try again.
what worked was, i wrote the pcm with out the fast write checked.
Disconnecting the battery would've also worked
to avoid this issue on most auto trans cars, one you have completed the read of the PCM/TCM you must turn the ignition key to off position.
then when you are ready to write, key to on position and you will never had to disconnect the battery at all.
