Tuning Noob in need of some guidance!
My setup is a 2004 CTS-V LS6 w/ Texas Speed PRC 2.5 LS6 heads with Torquer V3 Cam (111 LSA, 231/234 .643/598) 42# injectors, ported LS6 intake with the electronic LS2 ported Throttle Body, pacesetter headers magnaflow cat back, Volant CAI.
The car was professionally Dyno tuned but my LS6 throttle body died promptly afterwards and I replaced it with the professionally ported LS2 TB. When the car was tuned on the Dyno, the LS6 TB had a hole drilled in the blade, the new LS2 TB does not have the hole and as a result the car will not idle anymore, the minute I start it it dies.
There are three things I wish to accomplish so that I can get the car running long enough to utilize the data logging, scanning and wideband functions of HP tuners and further my education.
1. I added a 160 degree thermostat, is the only thing I need to tune for on
this is?
a. Fan 1 – On 184F ~ Off 175F
b. Fan 2 – On 194F ~ Off 185F
2. I read to Compensate for the LS2 Throttle Body on my LS6 by changing ETC scaler to 0.0191. Where is this located, is it under Engine--> Airflow --> Electronic Throttle?
3. Idle for Cam: What tables or parameters do I need to focus my education on to get the Electronic Throttle Body open enough that it won’t immediately die when I start the car so I can get some readings on A/F ratio, etc?
I've attached the stock HPT file as well as my current HPT file of the Dyno Tune done by Wong's Performance which is named "Wong CTS-V"
Any advice, feedback or noob bashing welcome!
Thanks Fella’s!
