I have a 6.0L LS style engine (lq4) retrofit w/ torquer v2 cam aprox (232 dur @ .050 and .598 lift int/ext). 1.7 stock rockers, Ported LS6 Heads milled to 61cc. stock mls gasket, 96 mm aluminum ls2 style typhoon intake, 96 mm professional products throttle body, 3.08 (soon to be 4.11). 46lb fast ls2 injectors. 24x reluctor, back top cam sensor, front o2’s only, 100mm 5 wire flat maf w/ iat sensor , truck 2002 coils with heat sinks, No vats, emissions, etc. Tremec t56 magnum 6 speed. Using a standalone wiring harness from PCI. PCI also gave me a computer with a modified basic tune from a 2002 1500 truck V8. They modified gear, vats, cyl vol and a few other things. See attached tunes. I modified it several times, but have 3 main versions. 1st is original tune from PSI, which started and ran, just did not like the 100 mm maf and other things. Ver2 which ran good but need VSS closer for spedo. V3 which I modified vss pulses, timing idle and a few other things. I was basically trying to start dialing this thing in. I did a write calibration only on all. Seem to program fine on v3 until it finish and instead of just turning the fuel pump on/off like normal it just started to buzzing the fuel pump relay continuously. Battery voltage is fine. Laptop running battery (full charge) and not plugged in. I have seen several instances where this has happened by searching in google and here on hp tuners bulletin board, even talks about the buzzing relay. I have seen where a few mentioned had ver 2.23 beta. I have 2.23.474. I purchase the professional version$$$$. have found no way to connect to pcm will not communicate any longer, not even with a scan tool. Most people have had to replace pcm and have found no solution. If I do that will I have to use 2 more credits($$$)? I just got hp tuners last week. Couldn’t I just download same vin to new pcm? Has anyone figured out how to recover the ECM. Please help?
