I have a 98 camaro, TFS, ls6 intake, headers, 150 wet kit. I just did the resistor trick and the intake temp is switching like it should and you can watch it change on the log, however when you watch the timing, nothing happens. I opened a intake advance pid in a histogram and that also shows no change in timing. This car is also showing almost 5* of knock with 11.5-12 a/f and even at 16* of timing it is still showing tons of knock. Would the knock be canceling out the iat timing? I am lost with this car..
any help would be appreciated
